OV 2500 error message on 6800 switch
Locked
manrubble
Post by manrubble » 09 Jan 2009 11:47
On one of my 6800 switches - in OV, the error "Failed (BMF)" shows up in the Last Upgrade Status field.
The switch is running fine and the lastest code upgrade seems to show the right microcode 6.1.3 907 R1
any idea on how to get rid of this error?
benny
Re: OV 2500 error message on 6800 switch
Post by benny » 12 Jan 2009 05:33
BMF can't be 6.1.3.907.R01 - this was never a valid Miniboot/Bootrom for OS6800. Please telnet to the 6800 and post the output of "show hardware info" for verification.
-benny
Benny
manrubble
Post by manrubble » 12 Jan 2009 12:10
Bromley-Dorm-6800-> show hardware info
CPU Type : PowerPC 8245,
Flash Manufacturer : TOSHIBA,
Flash size : 67108864 bytes (64 MB),
RAM Manufacturer : (null),
RAM size : 268435456 bytes (256 MB),
NVRAM Battery OK ? : YES,
BootROM Version : 6.1.2.49.R03 ,
Backup Miniboot Version : 5.3.1.91.R02,
Default Miniboot Version : 6.1.2.49.R03,
Product ID Register : 54
Hardware Revision Register : 06
CPLD Revision Register : 09
XFP Module ID : 00
backup miniboot mismatch?
benny
Post by benny » 13 Jan 2009 04:24
You should upgrade the Backup Miniboot to the same version as the others. Then upgrade to the latest AOS 6.3.1.R01. Which version of OV do you run?
-benny
Benny
manrubble
Post by manrubble » 14 Jan 2009 10:45
Thanks!
3.40 build 29
btw, I couldn't find anything on the alcatel support site for upgrading the miniboot? I looked in the hardware, switch, PDF's but no luck.
where would I find the instructions.
started to upgrade last weekend. I plan to use OV to do the rest.
benny
Post by benny » 16 Jan 2009 07:19
Well - you need to download the Upgrade-Procedures. Especially with the 6800 you need to be quite careful during the upgrade.
Login to the BPWS and go to: https://service.esd.alcatel-lucent.com/ ... witch_6800
There you will find the downloads for the upgrade procedures e.g. "OS 6800 6.3.1.R01 Upgrade Instructions"
Please note the different versions of upgrade instructions for the various products.
-benny
Benny
manrubble
Post by manrubble » 16 Jan 2009 08:57
found it!
Thanks Benny for your help...much appreciated.
Locked
Return to “Omnivista”
