Hi guys,
Please, i need a help.
My PABX is a OXE
When a try to delete a terminal in MGR>USERS>DELETE the system show me this: OBJECT -1: ATTRIBUTE 0: Impossible to put the terminal out of order
What i can do?
It's a ua32 board.
UA32 - Impossible to delete a terminal
Re: UA32 - Impossible to delete a terminal
Hallo,
any plugware implemented? Nightforewarding number ...
A lot of possibilities.
Regards, Wolfgang
Regards, Wolfgang
- frank
Did you try termstat to reset the extension ?
the last time i had this problem, there was a boss-secretary-relation on the programmable keys.
Deleting the special keys could help.
Murphy72
Murphy72
To delete the terminal you have to delete all programmable keys like mutiline,diversion then you can deleted.
Best Regards
Wadsultan
Best Regards
Wadsultan
becarefull , and check if the set is not supervised
