hello
bashardabbas
hello
Post by bashardabbas »
when iam work and finish my work how to delete all command i use it ,,, if any eng work after me and press UP can see what i print so how to delete it ????
Re: hello
In PBX stored - not only entered command for mtcl (f.e.) user, but login history, action in mao, call handling history, etc. :)
Do not enter a commands after which you will be ashamed. :)
When something happen with PBX - how to understand why this happened without history.
bashardabbas
Re: hello
realy i dont under stand you ,,,, can you repeat with another word ( simple word )
sadim
Re: hello
Post by sadim »
history -c
bashardabbas
Re: hello
really really thank you
Re: hello
bashardabbas wrote: 21 Jun 2017 06:20 realy i dont under stand you ,,,, can you repeat with another word ( simple word )
Clean history - not good idea. History can help in some trouble with PBX.
Check command "last" and "maohist" - you find additional info about stored history.
bashardabbas
Re: hello
vad wrote: 21 Jun 2017 06:37
i agree with you but sometimes in our work in police you need to secrete what you do so i ask about history
Re: hello
In such case - I understand your question.
Re: hello
But as I say before - exist not only "history" for entered commands (you can see it's with Linux command "history") but history for login, some action, management..
