hello
bashardabbas
hello
Post by bashardabbas »
hi ,,,, when i programed multiline on user in case incoming work good but when the user want to dail and make call how to make choice whta the number he want to dail from ,,, the main number or the multi line number
enio.eltz
Re: hello
Post by enio.eltz »
Just press the multiline key you want and dial. For example, three multiline keys. 2000 is the main number, 2001 and 2002 the other numbers. If you just dial the destination number, it uses the main number 2000. But if you want to make a call from 2001, press multiline key 2001 and dial and so on.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
bashardabbas
Re: hello
i try that but when press then dail from the main number :(
bashardabbas
Re: hello
plz plz plz i need solution :(
tgn
Re: hello
Post by tgn »
bashardabbas wrote:plz plz plz i need solution :(
you have to pay a businesspartner, if you need an answer in a timely manner.
all people here are doing this forum here on a basis of free will (and spent mostly their free private time).
back to topic. there is an option in user management under multiline options. after you set this option, you have to choose the multiline before and after offhook.
regards...
Re: hello
Make easy test (f.e. you have multi-line keys 3000, 3001, 3002):
- press key 3000 and make internal call, press key 3001 and make internal call. On called set - you have 3000 and 3001 or 3000 in both case.
bashardabbas
Re: hello
vad wrote: 07 Jul 2017 00:39 Make easy test (f.e. you have multi-line keys 3000, 3001, 3002):
i try that but not worked before i make a internal call i press the multiline but the number show the main number
but when i recive call it work good
tgn
Re: hello
Post by tgn »
tgn wrote: 06 Jul 2017 15:28 back to topic. there is an option in user management under multiline options. after you set this option, you have to choose the multiline before and after offhook.
have you checked this?
Multi-Line Properties
Automatic Outgoing Seizure + False
regards...
bashardabbas
Re: hello
thank you very much its work now
