Dear all,
i face a problem in trunk line its status is "HS " when i reset coupler its status become free and after some time revert to HS .
when users unable to us this line it gives them line congestion.
attached show trkstat , and trkvisu.
kindly help to solve this problem.
trunk line error
trunk line error
Re: trunk line error
HI
desactive tone on seize and see if u're realy getting the pstn dial tone when u use prefix , or plug in an analog set to see if dial tone is present!
need also trunk cos
prefix meaning (bloc or overllaping mode)
need also trunk cos
the actions i did
1. reset the coupler, then from 4019 telephone set try to dial trunk group prefix "82" to get it give me tone but only for seconds after dialing three or four digits, error tone and screen shows " Network Congestion", the trunk seizer type " professional Trunk seize"
attached trunk COS of this line.
check your trunk on your mdf with analog set, may be the line has problem from your telecom company
I already,did this check with analog set and the line work fine
the problem solved.
It was a bad contact problem from Telecom Frame side , I replaced the termination place at the frame and it solve the problem.
Thanks all for your support
