PSAL wiring guide
zetor2000
PSAL wiring guide
Post by zetor2000 » 15 May 2019 09:05
Hi!
I received a rather old shelf. It has 10 card spaces. It has a metal box with 3 connectors on the back, 2 of them are +48V and 0V, and the third is labelled "PSAL". I connected the +48V and 0V to a UPS, and the CPU board attached to the cabinet shows signs of life thru a serial console, but the boot does not occur.
The only thing it shows is that the bios version is built before Christ, and there is a "PSAL ALARM, Waiting for blahblahblah"... so there is a problem with the power.
How or where do i need to attach the psal wire?
I found documents from rel 5.1, but this rack was not mentioned... i think it is ~20years old, or more, but i could use it as a service cabinet.
Re: PSAL wiring guide
Post by vad » 16 May 2019 07:46
Connectors marked +48 and 0? Or -48V?
If you connect PSAL connectors to -48V - your CPU can works.
zetor2000
Post by zetor2000 » 29 May 2019 15:41
Thank you, Vad!
I suppose the label shows 48V / 0V / PSAL, the polarity of the 48V is unknowwn. I do not remember. I have to check it, if i get back to my site. :)
I can only remember, if i made a wrong connection, my power sdupply's circuit breaker was shut down the power.
