I have an installation of OXE with Appliance server in the main location and 6 Remote IP media gateways in 6 different locations.In each locations there is IP phones, SIP phones and analog phones.The Remote sites have connectivity with Main location and there is firewall in both sites. There is limited number of ports which are necessary are opened in the firewall. IT department is asking me that which are the ports to be opened for IP telephony in Main and Remote sites.Anybody has idea about this?
Thanks in Advance,
C.B
Ports to be opened for Remote shelf
Re: Ports to be opened for Remote shelf
there is a excel dokument in the ALU businesspartner portal. it includes macro function. you can put your oxe ip equipment in separate locations, press a button and finally the macro will generate a list which port-ranges must be openend.
regards...
regards...
Thanks a lot tgn. I tried to find that document in Portal website and I couldn't. Can you please tell me the name and location of that document.
Thanks,
C.B
Thanks,
C.B
Actually you can find this file in the system documentation folder.
It is the only one xls file in a \cdrom\content folder.
or take a look under ->
System Documentation
/ System Services
/ IP Services and Port Numbers
regards...
/ System Services
regards...
yes; I found it. Thank you very much tgn.
Thanks and Regards,
C.B
Thanks and Regards,
C.B
Thank you all. I found the file and configures ports accordingly in firewall and is working fine.
