REASON OF THE REBOOT - OXO
Hi everyone,
I checked the form but i can't find the answer, so i am posting here.
We have customer with OmniPcx Office in R410.66 with CPU-2 . Every day in the morning the system will be in down, after the reboot then it will start working. Some times it will go factory default, after to put the latest backup it start working.
Issue is we can't find the reason of the reboot of the PBX. customer is 100% sure its not a Power Issue, because PBX is sharing the power where the other IT equipment's are connected with central UPS.
i tried to connect via web https://oxo ip address/services/webapp where we can normally get some logs. But the web connection getting rejected. So i don't have any idea why the pbx is going down every day.
Its a bank customer, so issue getting serious. please advise me if any comments on this..
Thanks & Regards,
Rajan
Thanks & Regards,
Rajan
- cavagnaro
Re: REASON OF THE REBOOT - OXO
Oxo acts on mysterious ways that only true believers can understand...
Probably faulty HD. Make a backup and replace. Why? Cause it is OXO way.
Bank...Oxo? Ok...
Bank...Oxo? Ok...
Hi cavagnaro,
Thanks for the replay. There is no HD in the CPU. its with internal flash. And after format and if i put the same backup, i don't think it will resolve.
And today the system didn't went down, i don't know why.
Anyhow i will keep monitor..
Rajan
Rajan
Preferred way is to upgrade your system so you get official support. Upgrade to the latest R10 is not very expensive - you get new CPU + support.
If this is not an option - you're on your own with that old SW and old HW.
So connect to "config" port with V.24 cable and switch this port from ppp mode to tty/login, restart PABX. Then you get log of events during shutdown/startup.
Old releases like R4 had this kind of problem. They restart for nothing. Usually, some process fails and the system restarts. With the logs of config port you can see something, usually the process that stops, but you would need ALE help to get solution and, in this case, R4 is phased out.
As alex wrote, it is interisting to upgrade the system to the latest release R10. It is stable.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Hi all,
I know this is off the topic but can you tell me where can I find user/pass for this service?
Lido
Lido
Seems weird but you can find it in official OXO documentation. E.g. "Web Based Tool" 8AL91208USAC Ed.1liridonq wrote:Hi all,
Lido
Wow really ? ... that is weird .... I meant where in the OXO MMC, I've used all the credentials from this panel (System Miscellaneous - Passwords - Management Passwords) with no luck, it keep saying "Please authenticate to access this zone"
Anyway, thank you
Lido
Anyway, thank you
Lido
OK. Now I see. Try to put login name in small letters, like "installer" not like "Installer".
That is correct, it is case sensitive
Thank you
Lido
Thank you
Lido
