I am Beginner in Alcatel PABX Systems and i need help to interconnect two omnipcx.
We have two omnipcx Small Office that can be connected in the same lan.
the first one use 2 digits Numbering plan, the second 3 digits.
can you tell me how can i connect the two omnipcx and make calls between the two subnetworks please.
i need to know all the prerequisites (Hardware, Card, Licences, QSIG or other technics...)
Advise please.
Thank you in Advance.
Interconnect Two OmniPCX SmallOffice
Re: Interconnect Two OmniPCX SmallOffice
hi
if you have same lan for both or inteconnected lan ,best option is to interconnect them on ip,sip etc .. indeed it depends on locks that u have on your systems may be you need some extra licences end voip cards (new cpus).
btw search in the forum lotof similar cases were discussed .
Thank you for your reply,
believe me, i did many search before writing this post. can you advise me some links please.
Thank's.
Thank's.
The first what you need - system documentation for your SW version. In doc - exist explanation and examples.
totaly forgotten of corse system doc ! you can have some exemples
Thank's a lot.
