subscribers / sip account
hello,
it is possible to config the oxo that subscriber 1 call over sip account 1 and subscriber 2 call over sipaccount 2
i have a few accounts not a trunk and will bind each account to different subscriber
all sip accounts are from same provider
thx
thx
- giovanni.attolini
Re: subscribers / sip account
No, is not possible have two SIP accounts registered in the same sip server in OXO.
Giovanni A. Attolini
giovanni.attolini wrote: ↑18 Sep 2017 08:14 No, is not possible have two SIP accounts registered in the same sip server in OXO.
thx 4 your answer,
maybe with asterisk between ???
- giovanni.attolini
Yes, but to alternate the outgoing calls between sip accounts you will need verify the caller ID in the asterisk dial plan.
Notice that you can't create two sip trunks with the same ip destination in OXO.
From SW version 10.2 or 10.3 you can have several SIP-accounts with one SIP provider.giovanni.attolini wrote: ↑18 Sep 2017 09:13 Notice that you can't create two sip trunks with the same ip destination in OXO.
- giovanni.attolini
Is not what my OMC is telling me.
In some TCs for SIP provider setup for OXO it is written how to have several accounts working with one SIP provider.
You have only one gateway defined and two SIP accounts assigned to that gateway.
Like that
Like that
- giovanni.attolini
Very strange because here is not possible to create two accounts with the same gateway parameters.
Alex, do you know the TC number?
E.g. this one:
TC2154 "SIP TRUNK SOLUTION SYNELYANS (FR): CONFIGURATION GUIDELINE RCE102"
2.4.2
In case of subscription of multiple SIP accounts with the Operator, it will be necessary to add more Public Numbering Plan lines and
accommodate the "SIP Acc Index" of each new line accordingly
thx alex,alex wrote: ↑19 Sep 2017 00:42 E.g. this one:
TC2154 "SIP TRUNK SOLUTION SYNELYANS (FR): CONFIGURATION GUIDELINE RCE102"2.4.2
any idea how the internal plan should look like? or a right config ???
