SIP Trunk OxO CE
Belnadifia
SIP Trunk OxO CE
Post by Belnadifia » 25 Feb 2018 10:16
Hello there,
I'm not an installer nor telephony pro, just a guy who love technology and stuff !
A friend who work for a company that rent equipments to another companies has recuperated an OxO Compact Edition and give it to me for free (and a 4029 + 4039 phone) !!
It came with a CPU4 and a Mixed 2/4/4 boards (XMEM Daughter board with SATA HDD).
It's the first time I touch a PABX and I'm learning alone in my room :)
I successfully get a AA and configured subscribers.
Internal call work fine, Mailbox too.
But now I'd like to get access to external call (incoming call firstly). BUT ! I haven't T0 line at home (Nor PSTN), but I have a SIP account with 2 simultaneous lines.
The problem is : My PABX doesn't allow me to setup a connection to a SIP Trunk.
I understand that there Software Licenses limitation, but I'm lost !
Also, I read that CoCPUx can't work standalone with a Compact Edition !
But If a get the VOIP4 Daughter-board of a CoCPU2 and plug it to my CPU4 instead of XMEM daughter-board, will it work ?
I mean, is the fact of getting a VOIPx plugged on CPU board, automatically give the rights to use IP function ?
Finally, I saw the BeroNet solution, a gateway beetween SIP account and T0. But it's a little bit "expensive" just to have fun with technology without a professional use :D
For you, what's the best solution ?
Thank for reading, and be gentle with my french english :)
Belnadifia
Re: SIP Trunk OxO CE
Post by cavagnaro » 26 Feb 2018 08:12
If you don't have license maybe get an apa board which is analogic and you could use your homeland phone or connect a cheap sata sip device.
Getting license for just playing will be expensive
alexeik
Post by alexeik » 26 Feb 2018 08:17
since its a compact, an apa will not help... no empty slot.
he needs an amix i think... or cheaper sip t0 device. in germany we use an BeIP+ from bintec...
But i dont know if it supports your provider...
Belnadifia
Post by Belnadifia » 26 Feb 2018 12:54
Thank you for your replies.
So with a APA board plugged onto a SPA112 for example, I could use my SIP account for external call ? (Incoming and outgoing ?)
But it require an empty slot on PABX, I can find some loose OxO with 3 slot for ~90€ it sound ok for me.
I think BeIP+ equal the BerNet gateway (maybe with more functions ?)
How much cost a license for SIP trunk ? (And where do you buy it ?) (curiosity, because I can't find any information about it :/)
So plug a VOIP4 DaughterBoard on CPU4 instead of XMEM one will not grant me the rights to use SIP trunk ?
Post by cavagnaro » 27 Feb 2018 09:53
No, the board (I am not OXO Expert and haven't touched one in like 8 years) may provide only compressors to use with voip... Not sure, but no, no board gives you license access, only hardware resources to use a license.
About license you need to contact a BP, search them at your country list directory at Alcatel-Lucent.com
Belnadifia
Post by Belnadifia » 27 Feb 2018 15:10
I see, than you again ! (Well, I buy a CoCPU2 for nothing, but it's ok, it will be usefull one day I guess :D (and it cost me just ~30€))
The APA board seem to be the best solution !
Since I get an included free external call (landline and mobile) with my ISP (but they don't give SIP password, they only loan SIP phone (or SPA112) preconfigured) and I have one more SIP account (with password, but no free call)
To be sure :
-I buy an APA-4 Board
-I plug 2 FXS of preconfigured SPA112 to 2 FXO of APA-4 card
-I plug 2 FXS of my SPA112 (my SIP account) to 2 FXO of APA-4
-I can setup OxO to use my ISP phone for outgoing call and my own SIP account for incoming call ?
-No licence needed ?
EDIT :
On my CPU4 Board, there is a "SLI 1/2" port. Isn't for Analog ?
Hmm sory, now I know that SLI is for analog Terminal Only, not analog trunk
Hey, the AMIX-444-1 looks great ! Compatible with the compact Edition, 4 analog trunk, 4 analog interface and 4 digitale interface !!
Belnadifia
Post by Belnadifia » 07 Mar 2018 13:06
Sooooo !
I get a AMIX-444-1 now
I also get a Cisco SPA112 (SIP to analog phone)
But I'm not sure where to start.
Can you help me to find a documentations to setup an external acces with analog trunk ?
Thank you :)
Return to “Beginner's questions about the OmniPCX OFFICE”
