Outgoing calls from OXO via PRA-T2 card
Rubik001
Post by Rubik001 » 04 Jun 2018 06:30
I have an issue related to outgoing calls from OXO via PRA-T2 card.
I'm connecting the PRA to a E1 card (ETSI PRI) in a MSAN,wjich is connected via SIP to a Lab SIP Server.
The layer1 seems OK, no alarms.
I can make calls from MSAN to OXO, but when I try to call from OXO susbcriber, after the dialling is finished, I get congestion or busy tone immediatelly.
I suspect something is missing in my OXO configuration to allow the outgoing calls. Hope somebody can help.
The current configuration is below.
When I call to number 2200, the call is correctly routed to OXO, and the user 104 rings, and the call is established.
But when I dial from 104 subscriber 02001, which should be translated to 2001, I get busy one.
Installation Numbers Table:
Installation Number: 2
International Prefix 00
International Code 34
Intercity Prefix 02
Intercity Code 02
Recall Prefix (empty)
Alternative System CLIP 2200
Numbering Plans Table:
Internal Numbering Plan
Main Trunk Group Start:0 End:0 Base: ARS NMT:Keep (Is it correct?)
External Numbering Plan
Subscriber Start:100 End:199 Base: 104 NMT:Drop
Subscriber Start:200 End:299 Base: 104 NMT:Drop
Subscriber Start:500 End:525 Base: 500 NMT:Drop
Restricted Public Numbering Plan: EMPTY
Private Numbering Plan: EMPTY
End Of Dialing Table:
Prefix:0 Counter:0 Open Dialing
Subscriber/Basestation List
01-005-01 104 Clasico
01-006-01 105 Clasico
External Lines
List of Access:
02-001-01 T2 P001 30 Channels
Additional details:
Protocol Type: EDSS1
Direction of B-Channel
Incoming:0
Outgoing:0
Bi-directional: 30
Public trunk (Checked)
Fixed TEI: 0
List Of Trunk Groups:
Index 1: 02-001-01 T2 P001 30 Channels
AUTOMATIC ROUTING SELECTION
Automatic Routing: Prefixes
Activation: Yes
Network: pub
Prefix: 02
Ranges: 001 – 010
Substitute: 2 (with the NMT:Keep, the 02 is translated to 2 ?)
TrGrList: 1
Called (ISVPN/H450): het
Rubik001
Re: Outgoing calls from OXO via PRA-T2 card
Post by Rubik001 » 12 Jun 2018 11:11
I was finally able to make the outgoing calls from PBX.
The issue was related to the configuration of LC category for subscribers and trunks.
It seems by default the calls via trunks are restricted by default.
freddiem
Post by freddiem » 08 Sep 2018 07:28
Good day!
I also have the same issue to configure outgoing calls for Alacatel Omnipcx. I am can receive calls from PSTN on extension 200, but I can not originate calls from any any extensions. A picking up a line and immediately I star dialling I get busy tone and the the circuit releases.
We have been assigned the following nummbers 0211427000 to 0211427029 and our internal number range from 200 to 160.
The following is the configuration done
[Installation Numbers Table]
Installation Number: 0211427000
International Code 26
Intercity Prefix 0
Intercity Code 0
Alternative System CLIP:
[Numbering Plans Table:]
Main Trunk Group Start:0 End:0 Base: 0 NMT:Drop
[External Numbering Plan]
Subscriber Start:100 End:199 Base: 200 NMT:Drop
Subscriber Start:200 End:299 Base: 200 NMT:Drop
[External Lines]
List of Access Details
Phy Add: 02-001-01 Type: T2 No of B Ch: 30
Additional details:
Incoming:0
Outgoing:0
Bi-directional: 30
Fixed TEI: 0
  • Phy Add: 02:001: Acc Type: T2 Identifier: PN No. of Ch: 30
    • Index 1: 02-001-01 T2 P001 30 Channels
      kindly assist on how I can configure ARS and/or out bound rules
Post by cavagnaro » 10 Sep 2018 08:43
Don't double post.
Return to “Beginner's questions about the OmniPCX OFFICE”
