Analog Interface to Digital Interface
baig219
Post by baig219 » 30 Jun 2018 06:31
We have an analog phone with a number and we using normal analog phone. But now we want to change that phone 4019 modal. Since it was mapped on analog interface we are unable to attach that new phone. Now we want to move that number from analog to a digital interface. but all digital interface already have some numbers mapped on them. My question is how we can switch numbers between analog and digital interfaces without any problems.
Device:- Alcatel-lucent omnipcx 10.1.24.1
Please help.
Re: Analog Interface to Digital Interface
Post by cavagnaro » 30 Jun 2018 19:24
Just delete it and create a new digital device with same number. Or just try to change the model, remember to convert the shelf board slot to 255
Post by vad » 02 Jul 2018 00:24
User/ Base station list:
- select user (digital, will use number from analogue phone)
- in fist row (upper) select "..." from right side of No. - you will have free and used numbers
- select number what you want (in your case from used number) - press Ok, press Modify (you will have notification about Inconcistancy), press Ok.
You will have digital interface with selected number and analogue interface without number.
Return to “Beginner's questions about the OmniPCX OFFICE”
