Problem with serial connection
micheleschelfi
Post by micheleschelfi »
Good morning everyone,
I've got a big issue with my Alcatel OmniPCX Office.
I've started working on a system built by someone else, and I don't know the password for OMC management system.
I found a way to reset the password using the config port and serial connection, but it doesn't work.
I used a standard "cisco" serial cable and the Putty terminal (trying all standard serial speeds), but i cannot see anything on the terminal. I've tried also another V24 cable (used for UPS), and with this i saw lots of strange symbols. But nothing clear.
Do you know if this is a cable problem? Or maybe is the config port damaged? What kind of cable should I use?
Do you know if exists a way to hard reset the system, and then manage it via Ethernet?
Thank you and sorry for my bad english.
Re: Problem with serial connection
For Cisco cable you need to cut it and reverse crimp an RJ45.
Return to “Beginner's questions about the OmniPCX OFFICE”
