Omnipcx Office WBM - Alcatel Unleashed
This can have several causes. I would think that the 4028 is from the new 1000Mb range and your PBX firmware should be upgraded to the latest available on ABPS or simply your IP configuration is wrong (or you have some clocked TCP ports on local ethernet or VPN).siptech wrote:I also tried https://192.168.92.246/admin
The 4028 phone gets to downloading config then hangs.
WBM won't help you. On OXO WBM is used only for maintenance and boot informations, or for internet services config --->not for voice service config. For that you need OMC.siptech wrote:The problem is that I cannot login to the WBM and dont have access to OCM.
TOT3KOPF is right that's he's tellin you that "WBM won't help you. On OXO WBM is used only for maintenance and boot informations, or for internet services config --->not for voice service config. For that you need OMC." because as i read your reply you're insisting that The problem is that you cannot login to the WBM and dont have access to OCM and thats why he's tellin you that. He's more knowledgeable on Alcatel Lucent than you. Try to read your replies man!siptech wrote:I thought this form was for " IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS". Why not just close this entire form and tell everyone to seek a dealer. I am trained in Avaya and Siemens, I know PBX systems. Just not Alcatel.
