Need to exit from downstat command
By mistake i just entered only downstat command without parameters via RMA login.
Now i am unable to exit or go back to main prompt.
I believe this will come back after restarting PABX. Can anyone give me a hint to resolve without restart ? and really appreciate.
I tried with ctrl + X / ctrl+Z / Ctrl + Q.
But no luck.
Melan
But no luck.
Melan
Re: Need to exit from downstat command
Not clear about main prompt (which one)?
mtcl session with CPU? For OXE - Ctrl+C
RMA prompt - Ctrl+AA
Hi Vad,
Thanks for your quick reply.
I was talking shell Prompt (1)xa000000>
I resolved this issue login to second CPU via RMA and executing bascul.
But I tried in lab OXE and it did not work.
I executed below command
(1)xa000000>downstat and press Enter
then I tried Ctrl+C to exit but it did not work.
Melan
Melan
strange - after downstat - I have after time-out some output and prompt. If I press Ctrl-C - command terminated without time-out.
Ctrl #
Or ctrl aa and then c 2 for Second v24
Then kill downstat
Then kill downstat
- cavagnaro
Guys please lets not answer the topics on "Chat" section...everyone is using it for everything. If you are going to answer lets move it to the right section.
Thanks!
Thanks!
All answers are possible solutions for the original problem.
I do not understand the reason for your posting, cav.
(I just described more details about the solution which worked at the end.)
- cavagnaro
Ah because the guy posted in Main Chat area. First place he lazy found. So users are using that section as "I'll post just here because I want to" and receiving answers. Just to keep the forum rules and order. Not because the answer itself. As usual your answers and vad are great. But if you see this posts in Main Chat or move or delete or don't answer so they post in correct section.
Thanks!
Sent from my XPeria Z
Thanks!
cavagnaro is right but very rude way to repond. the admin must be able to shift this conversation to the right place.
