Node Link Status
Node Link Status
Using incvisu I could see event log when a Node is Up and Down, but, How can I see the current status of a link ?
- cavagnaro
Re: Node Link Status
hybvisu -f all?
From my point of view more useful tool for network status checking - "suproutag" command (menu 2).
You can see - link status - X25, TDM or Hybrid channel, network status.
Hai all,
I have some problem with Node Link Status, i have 2 nodes when i used comment hybvisu all, the one node status Down, and the other Node status down, for exp my configuration
List of hybrid links of node 16
Hybrid link 2000 (N16N4) to node 4 (PERMANENT)
List of accesses
| | Main signalling support | Stby signalling support | Nb |
| Nb | GPA State Position Support | GPA State Support | trk |
| 1 | ON DOWN (19, 0, 0) IP | | 0 |
Hybrid link 2007 (N4N16) to node 16 (PERMANENT)
List of accesses
| 4 | ON DOWN (19, 0, 3) IP | | 0 |
TOPOLOGIE DU RESEAU DES COUTS TELEPH Qualite Voix
Noeud Local: 16
lqqqk lqqqk
x 4t-------------------------14------------14------------------------u 16x
mqqqj mqqqj
Local Node: 4
lqqqk lqqqk
? 4t-------------------------14------------14------------------------u 16x
mqqqj mqqqj
Cost = 1 (TS_FREE>=8), 2 (8>TS_FREE>=2), 3 (TS_FREE=1), S (TS_FREE=0)
X25D:<1> TELEPH:<2> Nx64:<3> FRELAY:<4> VPN:<5> QUIT:<Q>
COMPVISU IP NODE 16
Fri Dec 16 07:44:30 WIT 2016
| C O M P V I S U |
| Nber of used Ip calls => 0 | Nber of allowed Ip calls => 9 |
| TG | Name | IP address | Pos, IP Parameters |
| 10 | IP TRUNK | 10.91.21.71 | 2-0 , 32 comp, G723, Profile #1 |
COMPVISU IP NODE 4
Fri Dec 16 07:34:10 WIT 2016
| C O M P V I S U |
| Nber of used Ip calls => 0 | Nber of allowed Ip calls => 30 |
| 1098 | IP | 10.6.40.26 | 0-7 , 32 comp, G723, Profile #1 |
For the status IP already comunicate,
How solution for my situation.
List of accesses
List of accesses
Noeud Local: 16
lqqqk lqqqk
mqqqj mqqqj
Local Node: 4
lqqqk lqqqk
mqqqj mqqqj
COMPVISU IP NODE 16
| C O M P V I S U |
COMPVISU IP NODE 4
| C O M P V I S U |
At first - this is new link (not works from the beginning) or old one (works before and now stopped)?
Check (from both side):
- you can reach another side via IP (ping, telnet) - from local CPU to remote (use IP addresses as declared in - IP Hybrid link).
Thx for respon Vad,
This is a new link, i have already telnet from the other site (Node 4 IP 10.6.40.26), the all configuration has same from documentation,
Can you show me the running configuration...?
Thx.
Thx.
I have no configuration for example.
But configuration step (f.e. you have network 0 nodes 4,16):
Node 4
Internode links - create link:
Name - N4N16
Link type - Hybrid
Adjacent Network - 0
Adjacent Node - 16
Multi access - yes
For hybrid link N4N16 - create access:
Signalling type IP
Called Number or Main CPUa IP addr - CPU MAIN!!! address from node 16.
The same for node 16.
Node 4
Name - N4N16
Link type - Hybrid
Adjacent Node - 16
Multi access - yes
Signalling type IP
As I understand - node 4 - old node with some links.
Node 16 - new one.
One question - I hope you understand:
1 - exist network/node - from telephone system point of view - managed in System.
2 - exist network/node - from IP (IP/X25) point of view.
And for node 16 was done netadmin where was declared - IP/X25 used, node 16, network (0 or what network number you use).
Node 16 - new one.
thx for your respon what,
correctly, for node 4 the old node, right now have 3 network conect to node 4
and the node 16 new, will conecteed to node 4,
Point 1.exist network/node - from telephone system point of view - managed in System.
Point 2. exist network/node - from IP (IP/X25) point of view.
Consult/Modify: IP/X25 Tunnel
Node Number (reserved) : 104
Instance (reserved) : 1
Tunnel (LCN) Id : -1
Network Number : 1
Node Number : 4
IP Address : 172.30.1.4
IP Name : x001004_tun
X25 Address : ---------------
network number for the node 16 used 1 in IP/X25
already config with the doc, but progress still same,
List of accesses
Delivery software version : j1.410 ;
Patch version : 45 ;
Dynamic patch version : c ;
Before thx for your replay what,
Network Number : 1
Node Number : 4
List of accesses
So you have done the configuration from node 4 to node 16 have you done the reverse from node 16 to node 4 ???
can you show us internode link setups that you have completed on both sites?
