Analog trunk line terminate calls
Waelkaamalzaki
Post by Waelkaamalzaki » 01 Oct 2017 04:55
Dear Unleashed Team,
problem : we unable to receive trunk incoming calls , but no problem in outgoing calls.
the system : Crystal hardware and software version is 10 and Analog trunk card type is NDDI2.
troubleshoot actions :
reset coupler >>>> don't solve the problem
resart the PABX >>>>this solve the problem
Thank you for your support
Re: Analog trunk line terminate calls
Post by cavagnaro » 01 Oct 2017 12:17
Solves for how long? All lines have same behavior?
Waelkaamalzaki
Post by Waelkaamalzaki » 02 Oct 2017 03:35
1. this problem happens from two weeks, and every week we must restart the PABX,
2. this behavior happen in two analog trunk lines.
Post by cavagnaro » 02 Oct 2017 08:25
Maybe try to check cabling on those two. If you swap the line ports with others which work fine, what line fails?
If it is the same, then probably problem is that line.
If the working one begins to fail then you may need to change board to try to fix the issue
