IP Phones Connected
pdsgomes
IP Phones Connected
Post by pdsgomes » 14 Apr 2018 10:14
It's possible to see, via mgr or web, all the IP phones that are online and connected to the OmniPCX ?
Kind regards
mdhussainvlr
Re: IP Phones Connected
Post by mdhussainvlr » 14 Apr 2018 14:55
You can use ippstat command in mgr to check the IP phones on the node which will show the IP phone connected
pdsgomes
Post by pdsgomes » 15 Apr 2018 02:04
And the extensions?
alexeik
Post by alexeik » 16 Apr 2018 05:45
ippstat is for OXE, the post in oxo. Which pbx is it?
Edit: ah is see, it´s oxe, sry then it´s in the wrong section.
listout or listerm is what you need
Post by vad » 16 Apr 2018 08:50
moved in 4400/OXE
