Problem connect GD3 with CS
sito521
Post by sito521 » 21 Apr 2018 05:46
I am currently trying to connect a GD3 with the CS, but I can not register or download the configuration files
I have managed to configure the IP address of the GD card, and I have a ping with it, but I do not register.
The Media Gateway is created in the OXE, and has the MAC associated in the CS.
If we make a telnet we have been able to connect to the OXE and it shows the error:
Welcome to mg3
IP is 10.31.13.86
* Warning: connect to callserver failed! *
* Please use resolve_connect to get possible cause of failure *
mg3 login: root
Bienvenue to user root
tcp 0 0 10.31.13.86:telnet 10.26.143.1:10106 ESTABLISHED
-bash-3.2 # mgconfig
Sat Apr 21 01:03:08 UTC 2018
[Script /etc/rc.d/init.d/verify_ipmg (PID = 2343) started by "mgconfig"]
The ipmg.cfg is in good shape in RAM
Welcome to the GD configuration tool
Does anyone know why this failure can be?
How can I register?
Thank you very much!!!!!
mdhussainvlr
Re: Problem connect GD3 with CS
Post by mdhussainvlr » 22 Apr 2018 02:49
Is GD3 rebooting after that ??
sito521
Post by sito521 » 22 Apr 2018 06:03
Hello!! yes, the gd3 restarts continuously
fery_s
Post by fery_s » 22 Apr 2018 07:10
did you run lanpbxbuild command in cs?
sito521
Post by sito521 » 22 Apr 2018 07:28
yes,
(1)OXE_a> lanpbxbuild
Sun Apr 22 15:35:17 CEST 2018
Reading data from file.
1. View
2. Add
3. Delete
4. Modify
5. Move
6. Apply changes
7. Copy lanpbx to lanpbx-mipt
0. Quit
fery_s
Post by fery_s » 23 Apr 2018 00:19
sito521 wrote:
22 Apr 2018 07:28
yes,
1. View
2. Add
3. Delete
4. Modify
5. Move
6. Apply changes
0. Quit
use "lanpbxbuild -auto" then with lanpbxbuild menu 1 check the ip download.
did you set the tftp ip address in gd card and then reboot it?
Post by vad » 23 Apr 2018 00:29
On GD-3 - declared cpu_main address (not physical address)?
Exist incidents on CS about downloading or not?
CS and GD - in different subnet - do you have some restriction (tftp allowed or not)?
sito521
Post by sito521 » 23 Apr 2018 04:05
Hello!
I have managed to correct the problem with the indications.
With the lanpbxbuild command, I have managed to find the problem. The IP MAIN that appeared was not the correct one, it was another old one. We have corrected it and it is already working correctly.
Thank you very much for your help!
