Direct abbreviated number - list
Jed
Post by Jed » 11 Jul 2018 05:12
alcatel 4400
I'm creating Abb. No by: mgr > Abbreviated Numbering > Direct Abbrev. Numbers > Go down hierarchy > create
How can I list all of them, so I will get all of the Prefixes and their Call Number?
Thanks in advance.
Jed
Re: Direct abbreviated number - list
Post by vad » 11 Jul 2018 23:25
As usual in mgr.
You can press Consult/modify and specify exact item what you need
or you select all item (press "All instances"),
or set filters
sadim
Post by sadim » 12 Jul 2018 15:13
You can use the edabv command
Enviado do meu WAS-LX1A através do Tapatalk
Post by cavagnaro » 12 Jul 2018 17:42
Sadim why your signature is in Spanish? Where you from??
sadim
Post by sadim » 13 Jul 2018 08:25
Where did you saw Spanish ?
On my location, i see Portugal
Jed
Post by Jed » 08 Aug 2018 04:58
thx for tips.
Also ednump is good.
