CS2 Crystal INTIP3 network
IP and Voice over IP
hemantha_kasun
Post by hemantha_kasun » 29 Mar 2018 21:32
Hello Guys,
When im implementing a OXE system with CS 2 and Crystal hardware i faced for a problem. When i try to call from a IP Instrument to Analog or Digital set call failing with displaying network congestion. Could you please help ASAP
Kasun
mdhussainvlr
Re: CS2 Crystal INTIP3 network
Post by mdhussainvlr » 30 Mar 2018 01:05
Just telling by words how to imagine ?share the traces at least t3 traces
hemantha_kasun
Post by hemantha_kasun » 30 Mar 2018 12:42
hi
unable to get a trance in the net work im using Analog Digital and IP instruments. TDM network working fine
But IP to TDM failed with "Network Congestion" what are the parameters i need to follow in OXE?
oldboy
Post by oldboy » 30 Mar 2018 18:47
Firstly what has a T3 trace got to do with handset calling??? Sounds to me that you dont have compressors??
Any INTIP cards???
mdhussainvlr
Post by mdhussainvlr » 31 Mar 2018 04:29
Are you trying to connect both crystal and common hardware via IP trunk through INTIP3 ?
Post by vad » 01 Apr 2018 23:35
As I understand:
- just one PBX (CPU=CS2, crystal hardware)
- internal calls between IP and TDM internal set (no IP trunk, t3 not used).
You need to check number of codecs available.
- check incidents
- check codecs (compvisu lio)
Return to “IP / VoIP”
