OmniPCX-ISA-VPN Client-Forever4035
IP and Voice over IP
Bogdan
Post by Bogdan » 09 Oct 2009 14:17
I am trying to use forever4035 with an OmniPCX Enterprise via a vpn client conected to an ISA server.
I can ping from my computer to PCX and I can ping from PCX to my computer but I assume forever4035 can not boot.
If I am trying a manual tftp session to PCX I got the following error:
Error on server : Client request without requested ethernet address
Anybody has a solution ?
Thank you
Bogdan
Re: OmniPCX-ISA-VPN Client-Forever4035
Post by tot3nkopf » 14 Oct 2009 07:26
Probably you need to configure in such way that the TFTP request issued by the phone to hit the PBX, or to configure a local TFTP server with the requested files. Are you sure that all needed ports are active in your config?
L_lefante
Post by L_lefante » 30 Sep 2015 09:59
I am having a similar issue with SIP phones trying to get config files from OXE tftp server, at least tftp server shows same error. In capture I can see the phone is correctly trying to get the file from OXE, however the OXE response with:
Message: Client request without requested ethernet address
Any more ideas?
Return to “IP / VoIP”
