invalid data binary on IP touch 4038
thanzeel
Post by thanzeel » 03 Mar 2011 03:42
Dear all,
I'm facing issue with some IP touch 4038 phones. When the phone is booting up it displays a message "invalid data binary". Can you provide me a procedure for resetting the phone to the factory default settings.
Thanks and Regards
Thanzeel Shajahan
KIKA
Re: invalid data binary on IP touch 4038
Post by KIKA » 14 Jun 2017 16:34
I'm facing the same problem, does somebody solved?
Best Regards,
K
ACSE OXE R11
ACSE OXO R8
Post by cavagnaro » 14 Jun 2017 16:54
Binary is downloaded from PBX due a release upgrade at pbx maybe? If the firmware is maybe damaged or corrupted. Try do disable the reset after upgrade option on the set. Are these sets over WAN or LAN?
Post by vad » 15 Jun 2017 00:28
Set type declared and used - the same? May be declared 8038 but used 4038?
alex
Post by alex » 15 Jun 2017 05:31
Read TC1482 "IpTouch phones are malfunctioning after Software upgrade"
"In case you encounter this issue, the solution consists in the upgrade of the IPTouch version"
