Alcatel 4028 IP Phones not working when switch reboots
Kumaransimbu89
Post by Kumaransimbu89 » 21 Dec 2011 02:18
When Switch Reboots some 4028 IP Phones are not getting up. Manually has to remove the lan cable and reconnect then it is working . It is happening frequently in some 4028 phones.
With Regards,
Kumaran
Re: Alcatel 4028 IP Phones not working when switch reboots
Post by frank » 21 Dec 2011 09:55
So many phones can boot at the same time.
What's the size of your installation ?
What error message is on the phone ?
