The good part: Thank you for this hint! With this line the main update bin4018 was successful.
Connection received from 192.168.2.180 on port 1024 [13/12 15:33:25.361]
Read request for file <lanpbx.cfg>. Mode octet [13/12 15:33:25.361]
OACK: <timeout=5,blksize=1428,tsize=68,> [13/12 15:33:25.361]
Using local port 58537 [13/12 15:33:25.361]
<lanpbx.cfg>: sent 1 blk, 68 bytes in 0 s. 0 blk resent [13/12 15:33:25.361]
Connection received from 192.168.2.180 on port 1024 [13/12 15:33:29.358]
Read request for file <noe4018-header>. Mode octet [13/12 15:33:29.358]
File <noe4018-header> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [13/12 15:33:29.358]
Connection received from 192.168.2.180 on port 1024 [13/12 15:33:29.374]
Read request for file <noe4018>. Mode octet [13/12 15:33:29.374]
File <noe4018> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [13/12 15:33:29.374]
Connection received from 192.168.2.180 on port 1024 [13/12 15:33:33.371]
Read request for file <bin4018-header>. Mode octet [13/12 15:33:33.372]
File <bin4018-header> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [13/12 15:33:33.372]
Connection received from 192.168.2.180 on port 1024 [13/12 15:33:33.374]
Read request for file <bin4018>. Mode octet [13/12 15:33:33.375]
OACK: <timeout=5,blksize=1428,tsize=863417,> [13/12 15:33:33.375]
Using local port 58541 [13/12 15:33:33.375]
Peer returns ERROR <Abort transfer.> -> aborting transfer [13/12 15:33:33.642]
The phone says in it's soft-version settings NOE version is unknown and I can't change from NOE to SIP. I think the log above shows why this isn't possible - because the binary for this function is missing. I don't have these header files.
Maybe this user:
viewtopic.php?p=89046#p89046 has the nearly same problem? I also tried to rename the "datsip4018" file to "dat4018" in order to avoid the second file not found error in the log. But the phone says s.th. like "incompatible".
kind regards
kati
EDIT:
I startet Netlog to see whats happens on the phone:
<15> 00:00:05 000-00:00:05.640 MGR : mgr_startup: init status 3.00 started 192.168.2.180 13/12 16:21:09.637
<15> 00:00:05 000-00:00:05.640 INIT : ############ msg_event_init_status 192.168.2.180 13/12 16:21:09.637
<15> 00:00:05 000-00:00:05.640 INIT : ###########step_initscreen:3/5 config download 192.168.2.180 13/12 16:21:09.637
<15> 00:00:05 000-00:00:05.640 INIT : ###########step_initscreen,step:3 192.168.2.180 13/12 16:21:09.652
<15> 00:00:07 000-00:00:07.640 TFTP : canditate server 192.168.2.110 / requesting lanpbx.cfg 192.168.2.180 13/12 16:21:11.588
<15> 00:00:07 000-00:00:07.640 TFTP : elected server is 192.168.2.110 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 TFTP : option: timeout 5 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 TFTP : option: blksize 1428 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 TFTP : option: tsize 68 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 TFTP : xfer started 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 TFTP : free memory = 4744784 bytes 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 TFTP : 1st alloc = 1428 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 TFTP : xfer finished 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 INIT : found 1/0 CS line(s) in lanpbx 192.168.2.180 13/12 16:21:12.205
<15> 00:00:07 000-00:00:07.640 INIT : Maincpu IP_CPU changed, flashing new params 192.168.2.180 13/12 16:21:12.221
<15> 00:00:07 000-00:00:07.650 MGR : mgr_startup: init status 3.01 success 192.168.2.180 13/12 16:21:12.222
<15> 00:00:07 000-00:00:07.650 INIT : CODE binary is invalid -> force download 192.168.2.180 13/12 16:21:12.223
<15> 00:00:07 000-00:00:07.650 MGR : mgr_startup: init status 4.00 started 192.168.2.180 13/12 16:21:12.224
<15> 00:00:07 000-00:00:07.650 INIT : ############ msg_event_init_status 192.168.2.180 13/12 16:21:12.224
<15> 00:00:07 000-00:00:07.650 INIT : ############ msg_event_init_status 192.168.2.180 13/12 16:21:12.225
<15> 00:00:07 000-00:00:07.650 INIT : ###########step_initscreen:4/5 binary download 192.168.2.180 13/12 16:21:12.225
<15> 00:00:07 000-00:00:07.650 INIT : ###########step_initscreen,step:4 192.168.2.180 13/12 16:21:12.225
<15> 00:00:09 000-00:00:09.650 MGR : mgr_startup: init status 4.38 getting code 192.168.2.180 13/12 16:21:14.188
<15> 00:00:09 000-00:00:09.650 INIT : ############ msg_event_init_status 192.168.2.180 13/12 16:21:14.188
<15> 00:00:09 000-00:00:09.650 INIT : ###########step_initscreen:getting code 192.168.2.180 13/12 16:21:14.188
<15> 00:00:09 000-00:00:09.650 INIT : ###########step_initscreen,step:4 192.168.2.180 13/12 16:21:14.188
<15> 00:00:11 000-00:00:11.650 INIT : dhs3_get_xxxx: tftp://192.168.2.110:69/noe4018 192.168.2.180 13/12 16:21:16.171
<15> 00:00:11 000-00:00:11.650 TFTP : canditate server 192.168.2.110 / requesting noe4018-header 192.168.2.180 13/12 16:21:16.198
<15> 00:00:11 000-00:00:11.650 TFTP : elected server is 192.168.2.110 192.168.2.180 13/12 16:21:16.198
<15> 00:00:11 000-00:00:11.650 TFTP : recv( 1): 19 ERR(1:File not found) 192.168.2.180 13/12 16:21:16.198
<15> 00:00:11 000-00:00:11.650 TFTP : canditate server 192.168.2.110 / requesting noe4018 192.168.2.180 13/12 16:21:16.198
<15> 00:00:11 000-00:00:11.650 MGR : mgr_startup: init status 4.33 file not found 192.168.2.180 13/12 16:21:16.198
<15> 00:00:11 000-00:00:11.650 INIT : ############ msg_event_init_status 192.168.2.180 13/12 16:21:16.198
<15> 00:00:11 000-00:00:11.650 INIT : ###########step_initscreen:file not found 192.168.2.180 13/12 16:21:16.198
<15> 00:00:11 000-00:00:11.650 INIT : ###########step_initscreen,step:4 192.168.2.180 13/12 16:21:16.198
<15> 00:00:13 000-00:00:13.650 MGR : mgr_startup: init status 4.50 getting load 192.168.2.180 13/12 16:21:18.185
<15> 00:00:13 000-00:00:13.650 INIT : ############ msg_event_init_status 192.168.2.180 13/12 16:21:18.185
<15> 00:00:13 000-00:00:13.650 INIT : ###########step_initscreen:getting load 192.168.2.180 13/12 16:21:18.185
<15> 00:00:13 000-00:00:13.650 INIT : ###########step_initscreen,step:4 192.168.2.180 13/12 16:21:18.185
<15> 00:00:15 000-00:00:15.650 INIT : dhs3_get_xxxx: tftp://192.168.2.110:69/bin4018 192.168.2.180 13/12 16:21:20.172
<15> 00:00:15 000-00:00:15.650 TFTP : canditate server 192.168.2.110 / requesting bin4018-header 192.168.2.180 13/12 16:21:20.178
<15> 00:00:15 000-00:00:15.650 TFTP : elected server is 192.168.2.110 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.650 TFTP : recv( 1): 19 ERR(1:File not found) 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.650 TFTP : canditate server 192.168.2.110 / requesting bin4018 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.650 TFTP : option: timeout 5 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.650 TFTP : option: blksize 1428 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.650 TFTP : option: tsize 863417 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.650 TFTP : xfer started 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.650 TFTP : free memory = 4744784 bytes 192.168.2.180 13/12 16:21:20.475
<15> 00:00:15 000-00:00:15.660 INIT : __update_do_check: version 43180 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.660 BCOMPAT: binary is compatible 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.930 INIT : binary_checksum_bank 0: OK 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.930 INIT : binary_checksum_bank 1: bad header 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.930 INIT : cannot update - no rescue binary 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.930 TFTP : xmit( 1): 20 ERR(0:Abort transfer.) 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.940 MGR : mgr_startup: init status 4.51 no rescue binary 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.940 INIT : ############ msg_event_init_status 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.940 INIT : ###########step_initscreen:no rescue binary 192.168.2.180 13/12 16:21:20.491
<15> 00:00:15 000-00:00:15.940 INIT : ###########step_initscreen,step:4 192.168.2.180 13/12 16:21:20.491
<15> 00:00:17 000-00:00:17.940 INIT : binary_checksum_bank 1: bad header 192.168.2.180 13/12 16:21:22.781
<15> 00:00:17 000-00:00:17.940 binary_switch: unable to switch (invalid) 192.168.2.180 13/12 16:21:22.781
<15> 00:00:17 000-00:00:17.940 DEFENCE: reset__: [27] bootloader_end_job [H] (694 tskinit.c) 192.168.2.180 13/12 16:21:22.781
