IPTOUCH RESET CAUSE 32 IN THE HALF OF THE LEASE TIME
dryhouse
Post by dryhouse »
Hello guys,
the iptouch of the customer restart all the days with cause 32. The defence says EXCEPTION with the text tDhcpcStateTask. It happens each 3 days 12 Hrs, in the middle of lease time DHCP....
Someone with the same problem?
Regards.
may the force be with you....
sadim
Re: IPTOUCH RESET CAUSE 32 IN THE HALF OF THE LEASE TIME
Post by sadim »
Which dhcp server are you using?
Have you a ip capture?
dryhouse
Post by dryhouse »
thanks for you reply.
The DHCP is Infoblox. I not have capture, is not easy....
Regards.
