It depends, if you want to run your 4028 as a sip phone you need the sipconfig.cfg, if you don't, then you don't need it.
For NOE the phone downloads lanpbx.cfg and NOE<macadress>.cfg. lanpbx is the file that desides the tftp server and such,but I'm not quite sure what the NOE<macadress> file does, but it gets downloaded.
For dhcp you would need to set option 66 to the ip adress of your tftp server(the server with the lanpbx.cfg file) and 67 to "lanpbx.cfg" without the quotes. You might need option 43 aswell, but I don't know what it would say. Please search to forum for questions about Ip phones on external dhcp, they are more detailed than this.
When you do this it should work (I don't know if it will, but in theory it should)
pour le fichier sipconfig.cfg j'ai télécharger un fichier que j'ai completer avec mes infos SIP de 3cx. j'ai mis un serveur tftp sur mon PC il recupère bien le fichier mais impossible " no tftp reponse".
moi je veux pouvoir passer mon téléphone du mode NOE au mode SIP mais c'est impossible dans le menu du téléphone
j'aurai vrament besoin d'aide
Antonin
for the file sipconfig.cfg I downloaded a file that I completed with my SIP info of 3cx. I put a tftp server on my PC it recover the file well but impossible "no tftp answer".
I want to be able to switch my phone from NOE mode to SIP mode but it is impossible in the phone menu
Did manage to download the sipconfig.cfg file or not? Your sentence sort of says both.
To switch between application modes on a set follow theese steps:
1. turn off the set
2. turn it on again
3. when it's at network start press "i" and "#"
4. go to the "soft infos" menu
5. there is only one parameter here, click it to switch between "NOE" and "SIP"
6. click back
7. click on the running man on the top right
Your set is still as NOE, so is asking about full info on how to work as NOE. Your first task is to switch to SIP mode, otherwise you are doing circles without sense.
Check in your firmware allows effectively to change to sip mode, otherwise you need first to load a new binary.
Check the forum, the info is around. I don't have it at hand.
