Timestamp in t3 trace
joerg
Post by joerg » 05 Aug 2011 04:45
Hi my name is jörg and i new in this forum.
I will start her with an little question.
I search an doku or tool how i cann translate the Timeinfo in the trace zu an normal timeformat.
Example:______________________________________________________________________________
| (919476:228807) Physical-Event :
| long: 49 desti: 0 source: 0 cryst: 0 cpl: 9 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 20 96
I found no informations in the sys-doku that help me to decode the 919476:228807 to an normal time (expl.: 10:36:36 clock )
I hope anywhere can help me . thanks .
best regards
alex
Re: Timestamp in t3 trace
Post by alex » 05 Aug 2011 15:52
It is simple as that:
Answer the call (CONNECT) then go oh-hook after a certain time(RELEASE). Check the 1st part (before ":").
Then it would be clear.
Eliott
Post by Eliott » 15 Aug 2011 06:45
Enter the commanda "t3; tuner km; tuner +time; mtracer -au"
It will add a timestamp every 1000 messages.
The first value is 919476 and assumed the second one is 919586 => 110 => 11,0 Seconds (increasing by 1 means 100 ms)
Return to “Traces”
