hi dear alcatel man
i have pra e1 link and some of my incomming call is release during conversation.
in t3 trace i have this cause:
|______________________________________________________________________________
| (885298:030202) Concatenated-Physical-Event :
| long: 30 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 14 a9
| IE:[08] CAUSE (l=2) 82 93 -> [93] NO ANSWER FROM USER (USER ALERTED)
| IE:[1e] PROGRESS_ID (l=2) 82 88
| IE:[1e] PROGRESS_ID (l=2) 84 83
have you any idea what is the problem?
call release unspected
Re: call release unspected
We need complete t3 trace calling no and caling no without that how ?
here is the complete t3:
| (694457:021333) Concatenated-Physical-Event :
| long: 54 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 13 48
| IE:[04] BEARER_CAPABILITY (l=3) 90 90 a3
| IE:[18] CHANNEL (l=3) a9 83 97 -> T2 : B channel 23 exclusive
| IE:[6c] CALLING_NUMBER (l=14) -> 00 83 Num : 6388569973
| IE:[70] CALLED_NUMBER (l=4) -> 81 Num : 84855466
| (694457:021334) 1269: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 93 48
| (694457:021335) 1269: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 93 48
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (694457:021336) 1269: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 93 48
| (694458:021337) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 13 48
| (695064:021351) Concatenated-Physical-Event :
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 13 48
| (695065:021352) 1269: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : 93 48
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (695066:021353) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 13 48
In the below trace we are getting to know that OXE is receiving the disconnect message from the other end and this is not form the OXE side
thank you for your reply. as i know the NO ANSWER FROM USER (USER ALERTED) is the isdn code cause bye the remote connection but when i recive it from the public network provider is that mean the problem is in the oxe????HUSSAINQCS wrote: ↑07 May 2017 06:29In the below trace we are getting to know that OXE is receiving the disconnect message from the other end and this is not form the OXE side
No its not from oxe
