Audiocodec MP-112. New menu/software
FN_DK
Post by FN_DK » 04 Jun 2014 07:34
Hi All,
OXE R10, Common HW
I need to setup a analog fax with an Audiocodec MP-112.
Have done it serval time before without problems. This time it seem like the menus in the software have changed? I have done the configuration up untill where I need to set the "Endpoint Numbers". Until now this have been done in "‘Endpoint Phone Number Table’ page (Configuration tab > Protocol Configuration > Endpoint Number > Endpoint Phone Number)"
That menu is gone! So, does anyone know where to find/configure in the new software version?
Software version on the Box is:
Version ID: 6.60A.241.010
Best Regards
Re: Audiocodec MP-112. New menu/software
Post by tot3nkopf » 04 Jun 2014 07:57
If it is not covered by ALU in the latest IWR, I think you should raise that to Audiocodes support.
terjeornes
Post by terjeornes » 11 Aug 2014 08:39
I have the same problem, new menu software, have anyone got answer from Audiocodes support ?
Post by tot3nkopf » 11 Aug 2014 08:49
terjeornes wrote:I have the same problem, new menu software, have anyone got answer from Audiocodes support ?
Or maybe you can load the old firmware and use the instructions that you have...Audiocodes firmware and instructions on how to flash it is easy to procure..
FN_DK
Post by FN_DK » 11 Aug 2014 09:25
I had a talk with AudioCodec support and they sent me a working config file. I corrected it for my specific site and it worked!
Just be aware: I tested it only with an analog phone NOT WITH A REAL FAX. (Incomming/outgoing) Simply becuase the customer suddenly found out they did not want to use fax anymore!! But I expect it to work :)
Remember to change the IP adresses + user numbers (use notepad find/replace)
Best Regards
PS: let med know if it works so I can use it for other sites with fax
terjeornes
Post by terjeornes » 19 Aug 2014 13:49
This did not work, but the problem may be in the OXO, is it possible to hire some help to set this up ?
(I have set up an Konftel 300IP, and had to change VoIP Parameter from H323 to SIP.)
FN_DK
Post by FN_DK » 20 Aug 2014 04:03
I did this on OXE. Afraid I can not help with OXO. Tho my advice is that you start testing ur global SIP setup with a SIP software phone. Ex. with a X-lite SIP phone.
Post by haroun » 20 Aug 2014 04:13
[Voice Engine Params]
CallProgressTonesFilename = 'usa_tones_13.dat'
FaxTransportMode = 0
V22ModemTransportType = 0
V23ModemTransportType = 0
V32ModemTransportType = 0
V34ModemTransportType = 0
TTYTRANSPORTTYPE = 1
terjeornes
Post by terjeornes » 20 Aug 2014 08:56
It is working, after some studying of other SIP communication i got it to work, the Audiocode it is connected to a modem and not fax, but i guess that should be the same.
Thanks to FN_DK.
Return to “AUDIOCODES”
