I tried to work swinst ff ds dupicate operations / clonning database, I spent the first step "Cloning chorus data" but in the second stage he threw an error. And now whenever I try to connect to the stby it gives me the following message:
4.3 BSD UNIX (a4400a) (ttyp0)
login: mtcl
Password:
/chetc/setlogprio: syntax error at line 1: `root:ZfT6s8caR9Bck:0:1:0000-Admin' u
nexpected
Lost connection to the host.
is there a solution to this problem end to copy the configuration of the hand to the twin cpu
thanks
cpu problem with the twin version R2.1
Re: cpu problem with the twin version R2.1
reinstall the second cpu, then clone db.
maybe hdd is corrupted?
anyway: R2.1, not a time to upgrade?
How to reinstall the database in the second cpu knowing that a message
nexpected
that prevents me from connecting on the second cpu.
nexpected
i mean, whole CPU.
with hdd reformating.
i mean, whole CPU.
please how to reformat the hdd
call service.
sorry, you need a lot of patience for this Release and very old software.
Maybe even PC with windows as old as win'95 / win'98...
what else can I do
Make a backup and download it from CPU to somewhere else.
Buy another pair of CPUs as you probably have some CPU3_1 that takes 6hours just to load software.
I recommend you go to nearest ALU BP and ask how much for pair of two cpus or just replacement for one CPU.
you could have falulty: CPU3, RAM (32MB IIRC), HDD (~2 GB), all three of them are old and hard to get in good working condition.
You need software to upload, cable to connect to connecting box (telnet is not sufficient) and some experience not to broke down running PBX.
To upload software, you neex another PBX "cage", with just new spare CPU, can't install this software (R2.1) on PBX while it's working.
Lot of work, lot of things that could go wrong, lot of extra hardware you should get, docs, and software that could be not easy to obtain.
Hello
Thank you so much for your support and I can clearly see that I need an expert party hard in 4400 for solving this problem.
My question now is how to "resolved" to this discussion in this forum?
thank you
thank you
