Can we retrieve the OPS files on analog modem remotely
azhar
Post by azhar »
I would like to know whether we can retrieve OPS files from 4400s/OXEs using analog modem remote connection. Normally I have to be onsite and ftp to get the files. But lately, someone told me that we can retrieve the OPS files using the analog modem connection.
I have tried FileZilla to see if there is field where you can enter a phone number instead of a host IP address, but nothing to do.
Does anyone know how to do this and if yes, how?
many thanks. :)
krzysioD
Re: Can we retrieve the OPS files on analog modem remotely
Post by krzysioD »
this is VERY basic training.
Not on oxe, but on using terminals and modems.
Hint: modem file transfer protocol, for example Kermit.
commands are wermit (for 4400) and gkermit (for OXE).
your terminal software shoud support kermit file transfer.
Huh, i think that i'm too old and i do remeber the BBS era and modems with 1200 bps.
crashdump
Post by crashdump »
There are several easy ways of doing this, if you are on a OXE system try the following:
(1)xa000001> swinst
Password:
1 Easy menu
2 Expert menu
Q Exit
Your choice [1..2, Q] ? 2
From the next menu select option 5
5:OPS configuration
From the next menu select option 1
1:Backup OPS files on cpu disk
Confirm the backup of OPS files (y/n, default y): y
Once backup is completed, quit back out to the command prompt and then continue as follows:
(1)xa000001> cd /usr4/BACKUP/OPS
(1)xa000001> ll
total 112
-rw-rw-r-- 1 root other 13862 May 7 14:27 **********.hw
-rw-r--r-- 1 root other 558 May 7 14:27 **********.sw4760
-rw-rw-r-- 1 root other 10595 May 7 14:27 **********.swk
-rw-r--r-- 1 root other 46768 May 7 14:27 **********.zip
-rw-rw-r-- 1 root other 13862 May 7 14:27 hardware.mao
-rw-rw-r-- 1 root other 12002 May 7 14:27 hardware.old
-rw-rw-r-- 1 root other 80 May 7 14:27 ops.lis
(1)xa000001> gkermit -s *.*
The files will now be transferred into the relevant directory of your terminal emulation tool. When finished, don't forget to end the Kermit process; if this is not done it can lockout the remote access connection.
azhar
Post by azhar »
Thank you Crashdump!
Just one point I need to clear out. When you say terminal emulation tool, can it be the VT100 on Hyperterminal? Do I choose 'Transfer -> Receive file' then from there select 'Kermit' as the 'Receiving protocol'?
When you type gkermit -s *.*, does then send those files automatically? what would happen if I do not prepare the reception of files as in above (Transfer -> Receive); would it still receive the files?
Many thanks again.
cheers!
Az
torrentula
Post by torrentula »
Yes
Yes
The *.* specifies all the files in the directory you are in /usr4/BACKUP/OPS. Once you start the receive on your terminal, you will receive all those files.
No, you have to start the receive.
azhar
Post by azhar »
All very clear. Thank you T!
Az
azhar
Post by azhar »
Hi all,
Just to round up this topic a bit, I would like to ask whether the reverse is possible; I mean, can we send OPS files to the OXE/4400 using the analog modem. This would save a lot of travel/time and reduce our carbon footprint; a bit for the environment!;retrieve the OPS files, get Alcatel to modify them and then send them back, all at the lab in the office! :D
So, as with retrieve, can we send OPS files using the 'Send file' option on the terminal emulation tool. Because from what I understood from about, to receive file, you have to activate the 'receive file' option on your terminal emulation; how does the 4400/OXE know it will be receiving files?
thank you.
Az
Gedeon
Post by Gedeon »
Type man gkermit in google :
http://pwet.fr/man/linux/commandes/gkermit (2nd response)
G.
knightr1der
Post by knightr1der »
azhar - i know you are more clever than this!
gkermit -s (this will send from oxe to you)
gkermit -r (this will put oxe in to recieve mode waiting for you to send file)
Gedeon
Post by Gedeon »
Just check that the name of the files are in the good format (swk and not SWK, or mao and not MAO).
wermit (4400) and gkermit (OXE) can be used for transfer file trough modem connexion, like OPS, patch, binaries files (man gkermit to put the transfer in binary mode), or traces...
I recommanded to compress the fils before transfer with gzip -9 on OXE or zip on PC.
Binary mode is mandatory in this case.
G.
Return to “Swinst”
