Cisco/Alcatel issue
mistof_44
Cisco/Alcatel issue
Post by mistof_44 » 26 Feb 2016 07:27
Good afternoon,
I present you our equipment, a CUCM Cisco connecting by QSIG to a 4400 (node 1), and himself connecting by hybrid ip link to a 4400 (node 2).
Calls between the both nodes are working (by hybrid link).
But when a user in node 2 calls a Cisco user (hybrid->QSIG), I see Q931, but the call hang up as soon as there is a pick up.
In the other way, when a Cisco user calls node 2 (QSIG->hybrid), there is the same problem.
Now, Cisco user calls node 1 (QSIG), it's working.
A node 1 user calls Cisco user (QSIG), it's not working. (I see Q931, but the call hang up as soon as there is a pick up).
Do anyone encounter any issue?
Have a nice day.
mistof_44
Re: Cisco/Alcatel issue
Post by tot3nkopf » 26 Feb 2016 08:19
Can we see the traces on ISDN but also on the hybrid?
Return to “ON SITE TROUBLES”
