NEED R6.0.1-f1.603-1-aj ASAP
aflores
Post by aflores »
Dear friends, I hope everybody is fine.
To restore a system I need ASAP the R6.0.1-f1.603-1-aj version.
Regards.
AFlores.
oldboy
Re: NEED R6.0.1-f1.603-1-aj ASAP
Post by oldboy »
yeah i got it.... you got a ftp site?
aflores
Post by aflores »
I can share you a dropbox link. Post me a PM with your email I will sent a link
oldboy
Post by oldboy »
done
oldboy
Post by oldboy »
just zipping it up :) it will be with you shortly
aflores
Post by aflores »
Thanks.
aflores
Post by aflores »
Thanks oldboy.
issue SOLVED !!!, System working.
Return to “ON SITE TROUBLES”
