hello
I'm not a expert in snmp.
The only I know is to make the switch repond to snmp queries
Enable SNMP - Omniswitch 9700
dangkita wrote:If using SNMPv3, how do we configure?
9000E=>user cedric password ********* read-write all sha+des
9000E=> show user
User name = cedric,
Password expiration = None,
Password allow to be modified date = None,
Account lockout = None,
Password bad attempts = 0,
Read Only for domains = None,
Read/Write for domains = All ,
Snmp allowed = YES,
Snmp authentication = SHA,
Snmp encryption = DES
then enterin your Management station user and password of the user.
There is no more community map
Re: Enable SNMP - Omniswitch 9700
did anyone get SHA+AES working on 9700?
hello! i've managed to get SNMP working between omniswitch 6850 and a snmpwalk in same network, but i can't get it to work between my snmpwalk host and omniswitch 6850 in different but reachable networks, in example i have omniswitch1(10.1.1.1/24), omniswitch2(10.2.2.1/24) and snmphost(10.1.1.254/24), connected to omniswitch1. i'm configuring both devices with same conf:
user nms password password read-write all no auth
aaa authentication snmp "local"
snmp security no security
snmp community map "public" user "nms" on
and i get snmp output from 10.1.1.1, but i can't get output from 10.2.2.1 - is it because snmp host must be in the same network?
No there is no such requirement.
can you ping omniswitch2 from you managment station?
If not: Routing correct?, DefaultGateway set?
In most of the times the management Station does not reside in the same network as the switches. It will work.
Deactivate the firewall at your snmp server. Mostly this is the reason. Like devnull has written mostly the management servers in different subnets.
