Our OS9700 switch immediately closes the web interface as soon as a user logs in. The swlog shows a successful login using http or https. As soon as you login it flashes the screen white and returns to the login page without any error.
I have disabled QOS and that doesn't make a difference. This started happening randomly and now it is pretty consistent. Only occasionally can you get in via the web interface. It is doing it on all user accounts including the admin.
Any help?
9700 web interface closes immediately
Re: 9700 web interface closes immediately
Please check ip service, ip http, aaa authentication:
internal services such a FW, antivir and co.
THU MAR 07 14:25:44 : SESSION (71) info message:
+++ [SES] Authentication failed: Session 1, access type Http
+++ [SES] Session 1, user "admin"
+++ [SES] Session 1, IP address 10.173.12.100
THU MAR 07 14:25:44 : WEB (69) alarm message:
+++ HTTP login attempt failed!
-> show ip service
Name Port Status
ftp 21 enabled
ssh 22 enabled
telnet 23 enabled
udp-relay 67 enabled
http 80 enabled
network-time 123 enabled
snmp 161 enabled
avlan-telnet 259 enabled
avlan-http 260 enabled
avlan-secure-http 261 enabled
secure-http 443 enabled
avlan-http-proxy 262 enabled
-> show ip http
Web Management = on
Web Management Force SSL = off
Web Management Http Port = 80
Web Management Https Port = 443
-> show aaa authentication
Service type = Default
Authentication = denied
Service type = Console
1rst authentication server = local
Service type = Telnet
Authentication = Use Default,
Service type = Ftp
Service type = Http
Service type = Snmp
Service type = Ssh
-> aaa authentication http local
THU MAR 07 14:26:27 : WEB (69) info message:
+++ The HTTP session login successful!
