Hello ALL,
Could you explain these messages ?
What does it mean ?
TUE FEB 11 14:40:17 2014 INTERFACE debug1 CRITICAL ERROR !!!!!! CMM DATABSASE IS NOT IN SYNC
TUE FEB 11 14:40:17 2014 INTERFACE debug1 Recieved: UDLD_STATS for slot = 2
TUE FEB 11 14:40:34 2014 INTERFACE debug1 Recieved: UDLD_STATS for slot = 1
TUE FEB 11 14:40:37 2014 INTERFACE debug1 Recieved: UDLD_STATS for slot = 2
TUE FEB 11 14:40:37 2014 INTERFACE debug1 CRITICAL ERROR !!!!!! CMM DATABSASE IS NOT IN SYNC
TUE FEB 11 14:40:54 2014 INTERFACE debug1 Recieved: UDLD_STATS for slot = 1
TUE FEB 11 14:40:57 2014 INTERFACE debug1 Recieved: UDLD_STATS for slot = 2
Explanation of messages in swlog
Re: Explanation of messages in swlog
did you have activated UDLD?
you should have a look into the actual releasenotes (for newest release in your version). There you can check if between your used image and the actual one this messages are found/solved.
Otherwise you can try to find a maintanance window for update...
If there is no chance you must open a ticket at ALU.
Hello Silvio.
Thank you very much for your support !
Yes, we have UDLD enabled and seems for UDLD these messages are normal.
Concerning to message about CMM I made synchronization "copy working certified flash syncro" and messages stopped.
Also, I checked Release Notes and did not find similar issues.
This are debug1 Level messages, afaik is a log level info the default configuration for newer releases. So check whether this is by design or maybe from older releases.
I have seen strange errors on devices that were upgraded and kept an old loglevel
Hello devnull,
You are right, these message are result of command:
swlog appid interface level debug1
I increased log level for appid interface because we had problem with UDLD protocol.
We have 8 x 9702E switches that connected whith each other by ERP ring.
Each switch in ERP connected to his neighbour by LAG (8 x 10 GB).
Each interface in LAG has enabled UDLD protocol.
So we had flapping links in LAG by UDLD protocol by uknown reason daily.
Message in Omnivista "1008 is shutdown by a feature due to violation (bitmap: bEniSecurityPortUDLD)
We cleared optical patches in LAGs and most of links stopped flapping.
But we still had prolem with one LAG.
That's why I inreased log level.
After this I saw messages: INTERFACE debug1 CRITICAL ERROR !!!!!! CMM DATABSASE IS NOT IN SYNC
And as I wrote after performing command "copy working certified flash syncro" problem has gone.
I'd guess that "INTERFACE debug1 CRITICAL ERROR !!!!!! CMM DATABSASE IS NOT IN SYNC" means you have changed interface config, (e.g. udld or vlan or ...) but not written and/or synced that to the (secondary) cmm.. which explains why it is gone after a write memory.
As it is a debug1 level message i would not stress that to much
