Upgrade NI uboot in os-9800
miobil01
Post by miobil01 » 11 Jul 2014 15:15
What is the procedure to upgrade the u-boot of new inserted NI card ( OS9-GNI-C24) in a OS-9800.
Module in slot 11
Model Name: OS9-GNI-C24,
Description: 10-1000 RJ45,
Part Number: 902627-90,
Hardware Revision: E02,
Serial Number: K28Q1031,
Manufacture Date: JUL 16 2009,
Firmware Version: ,
Admin Status: POWER ON,
Operational Status: UP,
Power Consumption: 51,
Power Control Checksum: 0xe38b,
CPU Model Type : Motorola MPC8541 ADS,
MAC Address: 00:e0:b1:c2:fb:26,
ASIC - Physical 1: BCM56504_B2,
FPGA - Physical 1: 0007/00,
UBOOT Version : 6.4.3.479.R01, <----- In Use card whit a current UBOOT
UBOOT-miniboot Version : No Miniboot,
POE SW Version : n/a
Module in slot 12
Part Number: 902394-90,
Hardware Revision: C19,
Serial Number: H52Q0028,
Manufacture Date: JAN 10 2008,
Firmware Version: ,
Power Control Checksum: 0x6bad,
CPU Model Type : Motorola MPC8541E ADS,
MAC Address: 00:e0:b1:88:d7:ae,
UBOOT Version : 6.3.4.265.R01, <----- New card whit a old UBOOT
Re: Upgrade NI uboot in os-9800
Post by silvio » 13 Jul 2014 03:27
look at page 13.
miobil01
Post by miobil01 » 14 Jul 2014 10:50
Thanks for your reply.
I need to add different 3 NI :
Slot 6 OS9-XNI-U2, 6.1.5.479.R01
Slot 12 OS9-GNI-C24 6.3.4.265.R01
Slot 15 OS9-GNI-U24 6.3.4.265.R01
I will project to do these different thing, do you think that's ok ?
Put the U-Boot and miniBoot files of the présent version in the switch flash
CMD :
"update uboot-miniboot"
Erase uboot files to flash mem
"reload working no rollback-timeout"
"show ni"
Do I miss something ?
Post by silvio » 15 Jul 2014 03:48
it should work. Important is to make image update always before the uboot/miniboot update (like written in the RN).
minhtri_329a
Post by minhtri_329a » 25 Oct 2016 00:15
hi comunity
i wana upgrade the uboot but i can't find uboot file anywhere. :'(
who can help me, plezzzzzz
Post by silvio » 25 Oct 2016 14:15
sometimes there is a special zip-file available with miniboot/uboot and/or fpga. But sometimes this is within a GA-release.
Maybe you will find the wished uboot within an older GA (if this where the first GA where the newer uboot where necessary).
regard
