I have a 9700 that will not boot past uboot. Getting the error "bad magic number" on startup and when trying to get to miniboot. Is there a good resource/guide for restoring the file system on the flash? I did see a procedure for USB restore, however I cannot use a USB thumbdrive as those are not allowed at the facility I work in.
So far I've tried TFTP boot with no luck. I do have other 9700's available with working CMM's, I thought of trying to flash-synchro off of one of those but I didn't know if that will work or if there's a better way of restoring the switch.
Any help is appreciated.
Both CMM's stuck at uboot
Re: Both CMM's stuck at uboot
Please post more output.
If you can access miniboot you can try to recover using X/Zmodem see http://www.alcatelunleashed.com/viewtopic.php?t=19531 should be similar for CMM in 9700 otherwise search board here.
I can't get to miniboot.
I'm getting the same error. Where can I access the output to post it here, Devnull?
Both CMMs stuck at uboot
Yeah it should be about 14.8 volts ... thanks for the tip ... Ill replace the reg and see what happens from there
https://www.nacdd1305.org/
