Activate WebView on 6600 P24
blacky911
Post by blacky911 » 27 Feb 2011 15:51
Hello Community
I have a big Problem.
I can´t configure WebView on my Omniswitch 6600 P24.
I think i need a step by step introduction to configure the switch to get access to the Webview of my Switch.
I also don´t know really the IP of my Switch. I try it withe the command "ip interface "vlan 1" 192.168.0.1 vlan 1" but there is an error because the CLI means that it don´t know the command "interface".
What can I do to get access to the WebView or what can I do to Configure the IP from the Switch for connection via FTP SSH or something else?
I downloaded many pdf´s about the 6600 Family but nothing i try work and the CLI are not my best friend ;)
Please help me...
(Sorry for my bad english, I´m from Germany)
Thank you
Blacky911
blacky911
Re: Activate WebView on 6600 P24
Post by blacky911 » 28 Feb 2011 04:40
Okay i find the fault.
I didn´t configure the DHCP and so the PC didn´t get a IP Address.
I gave the PC a static IP and it work :)
- Blacky911
ether
Post by ether » 30 Dec 2014 05:41
Blacky911,
What command did you used to set the ip of the vlan interface?
