Replacement of OS7700
amel632
Post by amel632 »
Hi. I'd like to know if I can replace an OS7700 for one OS6400, is there any problem or no? The OS7700 seems to be failing.
The OS7700 has just 4 fiber ports working and 2 copper ports working.
Thank you.
Re: Replacement of OS7700
this should be possible with your 6 ports...
At 6400 all ports are 1G.
Also you have to check if your old fibre moduls (miniGbig/SFP ???) will be supported at the combo-ports of the 6400.
