Omniswitch 6400 - how to tag a SFP port
burtzz
Post by burtzz » 26 May 2015 04:58
Hi guys,
I'm completely new to Alcatel switching.
My experience comes from HP and Cisco products.
I configuring a simple scenario with one core switch and 3 edge.
All edge switches connect to the Core using fiber uplink with an SFP.
I have 2 vlans, the default vlan and vlan10. I have ports tagged on vlan10 on all switches.
I'm trying to propagate vlan10 from core to all edge switches, so I need to tag the uplink ports.
And here's is the problem, I can't manage to find where I configure the tag on the SFP port.
Over in "interface configuration" menu, the fiber uplinks appear as Hybrid Interfaces 1 2 3 4.
In 802.1Q (port tagging) how can I select these ports?
Because I guess if I tag Slot 1 Port 1 I will be tagging the copper interface and not the fiber, right?
rekeds
Re: Omniswitch 6400 - how to tag a SFP port
Post by rekeds » 26 May 2015 12:37
vlan 20 802.1q 1/1-4
something like that?
devnull
Post by devnull » 08 Jun 2015 03:35
Hybrid ports mean you can use Copper or SFP (same as hybrid ports in Cisco), but you configure the port (1/1) regardless of media that you use.
Cisco is same: you configure gig eth 0/24 and not "the sfp part only"
So tagging vlan 10 to the ports 1/1 is
vlan 10 802.1q 1/1
vlan 10 802.1q 1/2
vlan 10 802.1q 1/3
vlan 10 802.1q 1/4, as rekeds already stated
You know that you used a wrong categorty for the thread?
