Serial number is not displaying in cli
mhrahmanpt
Post by mhrahmanpt » 18 Mar 2013 01:05
Hi alll,
i was trying to find out serial number of 6850p from its CLI , but it is not displaying..
i am new to AL, let me know this error happens and wt it means. and how can i activate to see it..
please out put of "show chassis" ..
PMB-F1-TR247> show chassis
Chassis 1
Model Name: OS6850-P48,
Description: Virtual Chassis,
Part Number: 902542-90,
Hardware Revision: 02,
Serial Number: ,
Manufacture Date: NOV 22 2007,
Admin Status: POWER ON,
Operational Status: UP,
Number Of Resets: 1
thanks in advance..
in addition , let me know the availability of Alcatel VOIP study materials.. ? :)
Re: Serial number is not displaying in cli
Post by tot3nkopf » 18 Mar 2013 03:34
And what has this to do with "Jobs"? Topic moved.
Post by silvio » 19 Mar 2013 12:29
you should see the serial with show chassis /cmm/ni/module
If you have actual software and miniboot and the issue is still seen than you should open a SR at Alcatel. Are there any others issues seen?
regards Silvio
mhrahmanpt
Post by mhrahmanpt » 21 May 2013 00:41
silvio wrote:you should see the serial with show chassis /cmm/ni/module
regards Silvio
Dear silivio..
thanks for your help.. i can see serial number from the above all ( cmm , ni , module ) commands..
what could be the reason for not displaying in show chassis... ??
Regards.
Musthafa..
devnull
Post by devnull » 22 May 2013 05:08
May be a software bug? have you tried the latest Firmware?
amr_hashem
Post by amr_hashem » 15 Nov 2016 07:13
Many thanks for your help,
it's working fine,
regards.
