Hi Guys
I have a query and hoping someone can assist.
for a lab environment I have a ESXI machine with 4x virtualised OXE's
ip's as follows:
151.1.1.1/24
151.1.2.1/24
151.1.3.1/24
151.1.4.1 /24
I am trying to configure a 6850-24 to route between them.... with no luck
the config of my switch is as follows:
! Stack Manager :
! Chassis :
system name Test_Lab
system timezone EET
system daylight savings time disable
! Configuration:
! VLAN :
vlan 1 enable name "VLAN 1"
vlan 10 enable name "vlan_10"
vlan 10 port default 1/1
vlan 10 port default 1/2
vlan 10 port default 1/3
vlan 10 port default 1/4
vlan 10 port default 1/5
vlan 10 port default 1/6
vlan 10 port default 1/7
vlan 10 port default 1/8
vlan 10 port default 1/9
vlan 10 port default 1/10
vlan 10 port default 1/11
vlan 10 port default 1/12
vlan 20 enable name "vlan_20"
vlan 20 port default 1/13
vlan 20 port default 1/14
vlan 20 port default 1/15
vlan 20 port default 1/16
vlan 30 enable name "vlan_30"
vlan 30 port default 1/17
vlan 30 port default 1/18
vlan 30 port default 1/19
vlan 30 port default 1/20
vlan 40 enable name "vlan_40"
vlan 40 port default 1/21
vlan 40 port default 1/22
vlan 40 port default 1/23
vlan 40 port default 1/24
! VLAN SL:
! IP :
ip service all
ip interface "vlan_10" address 151.1.1.254 mask 255.255.255.0 vlan 10 ifindex 2
ip interface "vlan_20" address 151.1.2.254 mask 255.255.255.0 vlan 20 ifindex 3
ip interface "vlan_30" address 151.1.3.254 mask 255.255.255.0 vlan 30 ifindex 4
ip interface "vlan_40" address 151.1.4.254 mask 255.255.255.0 vlan 40 ifindex 5
! IPX :
! IPMS :
! AAA :
aaa authentication http "local"
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
session prompt default "Test_Lab"
! SNMP :
! RIP :
! OSPF :
! BFD-STD :
! ISIS :
! IPv6 :
! IPSec :
! IP multicast :
ip router router-id 151.1.1.254
ip router primary-address 151.1.1.254
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Link Aggregate :
! Port Mapping :
! VLAN AGG:
! 802.1Q :
vlan 20 802.1q 1/1 "TAG PORT 1/1 VLAN 20"
vlan 30 802.1q 1/1 "TAG PORT 1/1 VLAN 30"
vlan 40 802.1q 1/1 "TAG PORT 1/1 VLAN 40"
vlan 20 802.1q 1/2 "TAG PORT 1/2 VLAN 20"
vlan 30 802.1q 1/2 "TAG PORT 1/2 VLAN 30"
vlan 40 802.1q 1/2 "TAG PORT 1/2 VLAN 40"
vlan 20 802.1q 1/3 "TAG PORT 1/3 VLAN 20"
vlan 30 802.1q 1/3 "TAG PORT 1/3 VLAN 30"
vlan 40 802.1q 1/3 "TAG PORT 1/3 VLAN 40"
vlan 20 802.1q 1/4 "TAG PORT 1/4 VLAN 20"
vlan 30 802.1q 1/4 "TAG PORT 1/4 VLAN 30"
vlan 40 802.1q 1/4 "TAG PORT 1/4 VLAN 40"
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! Server load balance :
! System service :
swlog console level info
! SSH :
! VRRP :
! Web :
! AMAP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
! EFM-OAM :
! ERP :
! SAA :
! Loopback-detection :
! DHCP Server :
! WCCP :
ip wccp admin-state enable
! LLDP :
! Link-fault-propagation :
! DHL :
! PPPOE-IA :
Test_Lab exit
if i ping the IP address interface NATIVE to the specific vlan then i get a response.
for example:
i use port 2 on the switch which is tagged for VLAN's 20,30,40 and the native vlan for this port is 10..... this is where im connecting the ESXI box
if i know ping 151.1.1.250 (the ESXI PC) or 151.1.1.1 i get a response but don't get one if i ping 151.1.2.1, 151.1.3.1, 151.1.4.1
if i however the plug the Ethernet cable into a port with native vlan 20 for example... then i can ping 151.1.2.1 but non of the others again.
another strange thing is that if i ping the switches own IP's.... i don't get a response unless something is connected to the switch ie: a pc with an appropriate address 151.1.2.50 for example then i get a response when i ping 151.1.2.254..... this is the same for all the ranges respectively.
am i missing something??
Please help
hope this all makes sense
Andy
Intervlan routing with ESXI pc
Re: Intervlan routing with ESXI pc
The switch IPs should be up once a port with this vlan is up. If you do not have any port connected the vlan (and hence the ip interface) stays down. if you have e.g. a trunk port up (e.g. 1/1 - 1/4) the ips should be up.
show ip interface would show that.
As default gateway for your OXEs you have the correspondig switch IPs? From your description it seems as if you you missed to set a default gateway.
(Test with PC 151.1.2.50 connected to native vlan 20 and default gateway set to 151.1.2.254. As long as there is a esxi connected all the switch IPs must be reachable.
Test that!
Afterwards debug what is wrong with the esxi config
Test that!
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ VMWARE
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ DIALER
- ↳ VM_BACKUP
- ↳ ipview analyzer
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ infocollect
- ↳ motview
- ↳ Other Alcatel-Lucent tools
- ↳ OFFICIAL TC's
- ↳ sngrep
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
