Hi, just got my first refurbished switch.
It is a OmniSwitch 6850 48 port.
I am confused and surprised that it has a modular power supply and that it is removable if I wanted to stack a pair of switches together.
I do however seem to be lost though.
When pluging in the switch for the first time I am greated to a 0 on the LED readout and the OK is amber/ PRI is off/ PWR and BPS are Green.
I am assuming I have to configure something to even get this switch to be a dummy switch but seeing as I am still learning even the basic CISCO commands Im not sure where to start to get it to work.
Any all help is appreciated.
I did already splice a CISCO cable to work with the switch and can communicate with it through puTTY.
New to Alcatel, not sure where to start...
This is what I receive at boot
U-Boot (6.4.4.213.R01) (for OS6400, OS6850, and OS6855 platforms) (Jan 27 2011 - 05:18:45)
MPC8247 Reset Status: External Soft, External Hard
MPC8247 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8247 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel-Lucent OS6850 (Kite2)
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
Device 0: Model: SanDisk SDCFJ-64 Firm: HDX 2.33 Ser#: 014215B1706A1853
Type: Removable Hard Disk
Capacity: 61.2 MB = 0.0 GB (125440 x 512)
USB: scanning bus for devices...
USB device not responding, giving up (status=80000000)
0 USB Devices found
Hit any key to stop autoboot: 0
## Booting image at ff900000 ...
Image Name: miniboot-6.4.4.213.R01
Image Type: PowerPC VxWorks Kernel Image (gzip compressed)
Data Size: 1014773 Bytes = 991 kB
Load Address: 00005000
Entry Point: 00005000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
## Ethernet MAC address not copied to NV RAM
Loading .text @ 0x01000000 (1629912 bytes)
Loading .rodata @ 0x0118ded8 (349411 bytes)
Loading .data @ 0x011e33c0 (139148 bytes)
Clearing .sbss @ 0x01205350 (1560 bytes)
Clearing .bss @ 0x01206000 (1579460 bytes)
## Using bootline (@ 0x4200): flash(1,0)cmm:default h=192.168.10.1 e=192.168.10.1:ffffff00 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff f=0x1000 rs=0x10000000
## Starting vxWorks at 0x01000000 ...
USB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD Wind River Systems, Inc. 562 Initialized
M824xHCI Controller found.
Waiting to attach to USBD...Done.
0xffffde0 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
ataDrv call. 0 1 24 24 621 0 0
CS EEPROM Module ID: 42012216 , System type: 48 port 1000Base-T, with 4 combo ports, stacking - kite2
Adding 5597 symbols for standalone.
Check Disk Running ...
dosChkLib : CLOCK_REALTIME is being reset to THU DEC 27 00:00:00 1990
Value obtained from file system volume descriptor pointer: 0xf59b9d8
The old setting was THU JAN 01 00:00:00 1970
Accepted system dates are greater than THU DEC 27 00:00:00 1990
/flash/ - Volume is OK
Boot parameters are:
'flash(1,0)cmm:default e=10.255.24.81:ff000000 h=192.168.10.1 g=10.255.24.181 f=0x1000 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff rs=0x10000000'
AOS miniboot version: 6.4.4.213.R01
VxWorks (for Alcatel CMM Motorola MPC8248) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Jan 27 2011, 05:49:51.
Copyright Wind River Systems, Inc., 1984-2006
CPU: Motorola MPC8248. Processor #0.
Memory Size: 0x10000000 (256 MB). BSP version 1.2/1.
WARNING: Stopping in miniboot as directed by boot flags...
[Miniboot]->
- pci_clk 66666666
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
0 USB Devices found
[Miniboot]->
Re: New to Alcatel, not sure where to start...
Somehow the boot flags of your switch do not allow to start the aos. Please check the forum for correct command (should be in some "how do I recover my passwords" - can check later maybe
So are you saying instead of starting the Miniboot I need to start an AOS?
Sorry if what I wrote was confusing like I said im new to this and Alcatel is completely different than what im used to.
So I followed the instructions here:
viewtopic.php?f=191&t=25767&p=94582&hil ... ord#p94582
This has now caused my switch to now display the following:
This is really concerning me seeing as I have no Image files and honestly have no clue what to do from here.
If I messed up (Which I am thinking I did) I do have another switch I can mess with but I would appreciate it if you could be a little more informative on what and where I should look for advice.
- pci_clk 66666666
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
0 USB Devices found
## Using bootline (@ 0x4200): flash(1,0)cmm:default h=192.168.10.1 e=192.168.10.1:ffffff00 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff f=0x0 rs=0x10000000
dosChkLib : CLOCK_REALTIME is being reset to MON JUN 06 19:26:42 2016
'flash(1,0)cmm:default e=10.255.24.81:ff000000 h=192.168.10.1 g=10.255.24.181 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff rs=0x10000000'
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/K2os.img'...
Cannot find component(alcatelNetworking_kernel.lnk) in package(/flash/certified/K2os.img)!
Cannot find component(kernel.lnk) in package(/flash/certified/K2os.img)!
Unable to load kernel image from file '/flash/certified/K2os.img'.
Unable to boot from the CERTIFIED software release.
[Miniboot]->USB Disaster Recovery Activated
sysUsbDisasterRecoveryTask: ERROR: /uflash not found
You should try to do disaster recovery with USB.
Search for lots of (small - 256MB are fine) USB sticks in your office. Format them as FAT. Put a (empty?) file on it.
Test with your other 6850:
- connect,
plug them in
enter "usb enable"
It should give you some output.
afterwards "ls /uflash" should show you the file.
If you found a working stick (i had ~ 40-60% success rate with sticks)
usb disable, remove stick attach to PC.
create a folder on the stick
/6850/certified
and copy all image files in there (if you do not have it, download the ones from the second/working 6850)
- connect,
plug them in
enter "usb enable"
/6850/certified
