Layer 3 vlan interface is down
mike18
Post by mike18 »
Hi Everyone,
Current config on switch
vlan 120 enable name "VLAN 120"
vlan 120 port default 1/3
ip interface "vlan-120" vlan 120 ifindex 4
Port 1/3 is up and passing traffic
show interfaces 1/3
Slot/Port 1/3 :
Operational Status : up,
Last Time Link Changed : FRI APR 17 22:50:36 ,
Number of Status Change: 0,
Type : Ethernet,
SFP/XFP : Not Present,
MAC address : 00:e0:b1:a8:c7:3e,
BandWidth (Megabits) : 100, Duplex : Full,
Autonegotiation : 1 [ 1000-F 100-F 100-H 10-F 10-H ],
Long Frame Size(Bytes) : 1553,
Rx :
Bytes Received : 3214, Unicast Frames : 28,
Broadcast Frames: 0, M-cast Frames : 18,
UnderSize Frames: 0, OverSize Frames: 0,
Lost Frames : 0, Error Frames : 0,
CRC Error Frames: 0, Alignments Err : 0,
Tx :
Bytes Xmitted : 10174, Unicast Frames : 3,
Broadcast Frames: 0, M-cast Frames : 146,
Lost Frames : 0, Collided Frames: 0,
Error Frames : 0
show ip interface
Total 3 interfaces
Name IP Address Subnet Mask Status Forward Device
Loopback 127.0.0.1 255.0.0.0 UP NO Loopback
vlan-120 0.0.0.0 0.0.0.0 DOWN NO vlan 120
show vlan port 1/3
vlan type status
120 default forwarding
Need to confirm layer 3 interface is down because we have assigned no IP address to vlan 120 right?
Mike
Re: Layer 3 vlan interface is down
right, the ip address (in your network) is missing at your interface.
ip interface "vlan-120" address 192.168.120.1/24 vlan 120
But if this switch is only L2-device in this vlan (without any routing) than you don't need an ip interface.
You can delete it with:
no ip interface vlan-120
mike18
Post by mike18 »
Will do that Thanks a lot.
Mike
