OS6850 High Memory usage , need help
kaifengw
Post by kaifengw » 25 Jul 2016 09:38
Hi everyone
i am using 1 OS6850 switch for the lab working ,
The CPU/Memory utilization has been more than 90 always as following info.
SWITCH> show health
* - current value exceeds threshold
Device 1 Min 1 Hr 1 Hr
Resources Limit Curr Avg Avg Max
Receive 80 01 01 01 01
Transmit/Receive 80 01 01 01 01
Memory 80 91* 91 91 91
Cpu 80 97* 90 61 99
And below is our troubleshoot steps ,
1、Reboot switch and it's will be working fine some days but the CPU/Memory utilization will be back to high usage
2、We have upgraded the AOS to 6.4.4.707.R01, Also get above errors .
would you please assist us to fix this issue ?
get error messages every times in swlog
MON JUL 25 18:31:43 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:32:21 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:32:23 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:32:28 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:32:31 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:33:01 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:33:11 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:33:27 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 18:33:35 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 20:02:51 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
MON JUL 25 20:03:11 2016 SYSTEM info disk cache error: device f58dde8 block 0 errno c0003, disk read failed
3rdm4r
Re: OS6850 High Memory usage , need help
Post by 3rdm4r » 06 Dec 2018 10:20
hey kaifengw,
I now, its more than two years ago, but can you remember you how do you fix the "disk cache error" ?
You know its a hw issue?
Thanks in advance!
devnull
Post by devnull » 10 Dec 2018 08:15
Never had that.. as this is more or less broken, you could try to do a recovery by NewFs (which will more or less format that flash) in hope that it recovers.. you need to upload firmware (desaster recovery from USB/Xmodem) afterwards.
Check the forum for more info. prepare for the worst ;-)
3rdm4r
Post by 3rdm4r » 14 Dec 2018 06:33
thx devnull! you mean erase the flash with "diskInit" (Miniboot) and then a normal AOS-installation via USB-Recovery?
Before I do this, I will try your other clue with "fschk". ThankYou
devnull
Post by devnull » 14 Dec 2018 07:19
I have done it ages ago. so search the forums here and see whether you find some "recover 6850" threads.
i have no full documentation here, so research first!
3rdm4r
Post by 3rdm4r » 21 Dec 2018 07:11
normal erase via Miniboot / diskInit "flash" and then usb auto-copy bring no positive results... CF-Card low-level-format, new Filesystem (FAT) and the failure was disappeared - until now :)
greetz
