DHCP server
strelok
DHCP server
Post by strelok » 24 Aug 2017 14:46
Hello !
Is it possible to put in dhcpd.conf vendor-class (or vendor-specific parameter) ? Does such parameter exist ?
And where I can find all list of parameters for dhcpd.conf file ?
We have different ip phones and it send request to dhcp server with value vendor-class inside.
So, we would like to configure dhcp server with different vendor-classic parameters. And address will allocated from dhcp server depend on what vendor-classic value will taken by dhcp server.
Thank you in advance.
Re: DHCP server
Post by silvio » 24 Aug 2017 17:18
you will find all in the network configuration guide (at least for 6450 I have found it)
strelok
Re: DHCP server
Post by strelok » 29 Aug 2017 03:00
Hello Silvio.
Thank you for response.
In documents I could find only vendor-specific field. In our case we need vendor-class parameter so that for example cisco phone could take ip address from certain for cisco pool of dhcp server. Example from Lunix below:
class "cisco" {
match if substring (option vendor-class-identifier, 0, 5) = "Cisco";
class "yealink" {
match if
substring (option vendor-class-identifier, 0, 4) = "A580" or
substring (option vendor-class-identifier, 0, 5) = "udhcp" or
substring (option vendor-class-identifier, 0, 10) = "yealink" or
substring (option vendor-class-identifier, 0, 4) = "\000\0006=";
Also, we could be find some usefull info from VitalQIP documentation according note from switch guide. But I couldn't find any documentation in Internet.
Note. For detailed information on how to configure the DHCP server on OmniSwitch, see the Configuring DHCP Server on OmniSwitch section. The *.conf and *.pcy files can be created using VitalQIP, refer to the VitalQIP documentation for additional information.
