Reset password
aviviis
Reset password
Post by aviviis »
I forget my 6850 password , how can i bring it to default password ?
Re: Reset password
you will find some posts here in the forum for more details .... power down/up the switch, interrupt the boot, change the bootflag to 0x1000 so that the booting will end in the miniboot. There you are able to delete the usertable in the network-directory. than at the next boot flag back to 0x0. So the switch can now start normaly with aos and you can use the default admin password.
aviviis
Re: Reset password
Post by aviviis »
